morethan1
Gold Member
Condition
The dial and hands are in very good condition. The dial has some black marks at the top of the 12 o’clock marker. The seconds hand has some discolouration. The chapter ring has a very small amount of paint missing at 11 o’clock. The bezel insert is original and has a marks and dings all around. The bezel clicks solid as it should. The 12 o’clock triangle on the bezel doesn’t quite line up with the 12 o’clock marker on the dial. You can fix this if it really bothers you. I left it as is. English/Spanish day wheel.
The case has a few dings shown in the pictures. The case has not been polished. The crown screws down nicely. Watch serviced Jan 2017. All gaskets have been replaced (except the crystal gasket which is still good). New aftermarket crystal. New Seiko OEM flat vent strap on new spring bars.
Specifications
Brand: Seiko
Model: 6309-7049
Year: Circa April 1985
Material: Stainless steel
Diameter: 44mm (excluding crown)
Thickness: 13mm
Lug width: 22mm
Crown: Screw down
Bezel: Bi-directional, indexed w/60 clicks
Crystal: Hardlex
Caliber: Automatic 6309
Water resistance: 150m
Box & papers: None
Asking: $550 shipped
Specifications
Brand: Seiko
Model: 6309-7049
Thickness: 13mm
Lug width: 22mm
Crown: Screw down
Crystal: Hardlex
Box & papers: None
