SpillyJ
Grand Seiko High Beat 9S85 SBGH001
Available here is the High Beat version of the Grand Seiko Line.
For those not too familiar with the Grand Seiko Line, they are the best of the best in terms of quality, fit and finish. These are by far the best bang for the buck money can buy in watches today.
This watch I took in trade a while back, I have worn it in the rotation with others and it keeps great time.
There is one small blemish on the bracelet link near the watch head which is visible on the photos below. It can easily be buffed out professionally
The watch does NOT come with box or papers and is available for $4800 or a solid trade. This is the way I received the watch!
A truly stunning quality watch!
Here are the details from Seiko:
REF.: SBGH001
Driving system: Automatic with manual winding mechanism
Caliber No.: 9S85
Case: Stainless steel Case back: Stainless steel and sapphire crystal
Glass: High definition dual-curved sapphire crystal
Coating: Anti-reflection coating on inner surface
Clasp: Three-fold clasp with push button release
Power reserve: Approximately 55 hours
Accuracy: +5 to -3 seconds per day (under a static use) ; This accuracy is the result of measuring the loss/gain of the time for seventeen days before the inside movements of the watch are put in the case. The measurement has been done in the factory where temperatures or position of the movements are controlled. When the watch is actually worn, the accuracy should be from -1 second/day to +10 seconds/day (-1 second/day to +8 seconds/day for Cal.9S85, 9S86).
Water resistance: 10 bar
Magnetic resistance: 4800 A/m (60 gauss)
Weight: 151.0 g
Case size: Diameter 40.2mm**Thickness 13.0mm
Remarks
・Screw down crown
・Screw back
・See-through back
・Jewels: 37
Here are the pictures:
REF.: SBGH001
Caliber No.: 9S85
Weight: 151.0 g
Remarks
・Screw down crown
・Screw back
・See-through back
・Jewels: 37
