Well damnit...I put money down on a new motorcycle today so up goes the Speedy. I wear a diver daily so it makes more sense to hang on to it, though I’m not in a panic to sell and may decide to put up the diver if this hangs around too long. I sure will miss looking at this one.
I am the original owner, purchased in February of this year from a local AD so it has the 5 year warranty.
The bracelet was sized and worn for a few hours then swapped out for a JPM strap. I see no marks on the bracelet. Then it went on an MN strap by Erica. So two strap changes. I used the Bergeron tweezers so the lugs marks are very fine under a loupe, barely visible with the naked eye. You know how these polished bits get hairlines just looking at them. Under loupe there are also hairlines on the polished tops of the lugs. Timekeeping is excellent, on the plus side I recall, and not far off COSC - if that matters to you.
$5250 local deal, and likely $100 to ship as the box is massive and heavy.
Oh, the OEM straps and other goodies were never used, still in the original packaging. Complete kit, dated warranty card. Sleeve too.
I’m in Whitby, willing to drive as far as Toronto for a ftf and coffee.
Cheers,
Sean
EDIT: what appears to be a scratch on the lug back top right is actually a fibre of some sort. Promise!
Cheers,
Sean
