morethan1
Gold Member
Condition
This is a 62MAS with small crown. The dial is in excellent condition. The dial and hands have NOT been relumed. The crystal shows some cracking in the middle. There is also a slight crack at 5 o’clock. The caseback markings are worn, typical of the 62mas. The serial number is still legible. The case has some nicks and dings, please see pics.
The bezel and bezel insert are original. The bezel turns smoothly as it should. The watch comes on a NOS tropic strap with new springbars. The watch keeps excellent time. I have serviced the watch and replaced some bad parts, namely:
Specifications
Brand: Seiko Model: 6217-8000
Material: Stainless steel
Diameter: 37mm (excluding crown)
Thickness: 12mm
Lug width: 19mm
Crown: Non-screw down
Bezel: Bi-directional, no clicks
Crystal: Acrylic
Caliber: Automatic 6217
Water resistance: 150m
Box & papers: None
Heritage
The 6217-8000/1, or 62MAS (autoMAtic Selfdater) was the first professional diver from Seiko in 1965. It started the diver series for Seiko that continues till today. It was the first diver in Seiko’s lineup to feature an external rotating bezel, and a water resistance of 150 meters.
Asking: $2380 shipped
- Escapement wheel
- Click lever
- Rachet wheel
- Wheel bridge (replaced with jewelled bridge)
- Clutch
- Rotor (replaced with Seiko 6205 rotor)
Specifications
Thickness: 12mm
Lug width: 19mm
Crystal: Acrylic
Box & papers: None
Heritage
